So in the middle of Big Bend National Park, my serpentine belt snapped and took out my tensioner pulley and my idler pulley. I managed to get a replacement for all three from O'Reilly's and done back to the East coast. However, when checking in with my mechanic, he said the belt looks too tight (you can see the ribs from the backside. There's no way to adjust the tensioner, so do I need to replace it when I swap belts, or is there a break in period? The other issue is that my power steering pump is now leaking at the shaft. My hard line has a light leak but reservoir level seems fine. I've found little info on rebuilding them and IDparts has them for about 140. Should I swap both line and pump at the same time?
Well, it got you home!
When you need to go OEM is for things like this. Hoses, belts, alts, any reman anything, and just about everything at those box stores are absolute garbage.
As for your PS, where is it leaking from the hard line? Might just be the fitting that is not seated properly due to the impact of the belt snapping.
As for your pump, 2000 jetta pump is rebuildable. If your having your mech do the work, just get a new one, will be cheaper. I have rebuilt them before and seals for this are like $2 a pop. You should see if the shaft is bent though, spin it and see if it wobbles or use a dial indicator if you can. Just saying, if you have the tools, you can fix this for basically nothing, well if the shaft is strait but if you dont have those kinda tools, just get a new pump, belt, from ID
The tentioners are probably fine from autocvnt store.
i would say that they sold you the right belt as it did fit but clearly not a proper fit. Belts should NOT be a hit or miss fitment but at these stores they are. Size increments dictate that a belt will either NOT fit at all too tight or to slack.
