samistheman
Okay guys I need your help! Changed the injection pump on my 2003 Jetta. I out a 11mm on instead of the original 10mm. Got the car running but it idles real rough and high, like 1100rpm. The car drives great and has good power but idle is no good, tried to adjust idle with vagcom but it won’t work. Anyone of you had this problem or know what it could be? Any suggestions help! Thanks.
