1 qt of biodiesel for every 12 to 15 gallon fillup. Around B2.So what lubricity additive should I use? I just took delivery of a new Passat TDI.
Why??Tried Lucas Upper Cylinder Lubricant? Easily available, and personally I think it works way better at providing lubricity than PS.
You have a 2003 TDI. For modern CR engines, you would want to make sure that any additive you use is ULSD compatible. You do not want your additive to mess with your (expensive) emissions system. For this reason, I would stick with ASTM Biodiesel or a well known brand name additive like PowerService, Stanadyne, Opti-Lube, etc.Tried Lucas Upper Cylinder Lubricant? Easily available, and personally I think it works way better at providing lubricity than PS.
I have never seen on any additive vendor publish information that states how much sulfur their product contains.For modern CR engines, you would want to make sure that any additive you use is ULSD compatible. You do not want your additive to mess with your (expensive) emissions system.
Don
I run b20 all year. The infamous Spicer report convinced me that no additive is equal to bio for lubricity. We'll all know more in a few hundred k miles.
This is good advice for those of you with older TDIs.I run b20 all year. The infamous Spicer report convinced me that no additive is equal to bio for lubricity. We'll all know more in a few hundred k miles.
Abacus, looks great! I too am a 2 stroke oil & PS mix proponent. I use 5 oz of PS & 3 oz Merc marine 2 stroke every other fill-up. What are your quantities?
Looks clean. That's what I want mine to look like. I used 2 cycle oil until I discovered bio nearby. I also agree that b2 may be enough to provide good lubricity. . . I'm just using what is available locally.Already there, but I have been using 2-cycle oil instead since bio isn't readily available locally.
No lip at the top of the cylinder when I took the head off at 393,000 miles and here are some pictures of the pistons, which I just soaked up the coolant from and did not clean. Compression was still from 460 to 500 psi in all cylinders and the head had never been off the car.
I really expected to see a bunch of buildup since I'd been running it for a long long time.
I don't care what the reports say, I'll keep running it in my car, along with the Power Service.
Sorry I can't help with anything on the CR's, those are a whole different animal.
