Old March 29th, 2015, 15:32   #1
1gcrazy
TDI(s): TDI
Default Rough running 03 ALH and takes forever to start.
Hey guys, I'm new to the TDI World but I actually build 2.7t's and DSM's for a living.
I picked up this rough running TDI and have done a lot of reading so far and I'm not sure where to start.
Here's what I have so far.
I have a Vagcom and here are the codes:
2 Faults Found:
17656 - Start of Injection Timing Regulation
P1248 - 35-10 - Control Deviation - Intermittent
17964 - Charge Pressure Control
P1556 - 35-10 - Negative Deviation - Intermittent
Readiness: 1 2 0 0
I just checked timing and it's saying, "timing is to far advanced to be graphed".
There is also a lot of air bubbles coming to the injection pump.
There is lots of white smoke on deceleration while in gear as well as when you start the car.
1gcrazy is offline   Reply With Quote
Old March 29th, 2015, 16:43   #2
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
First thing to do would be to get the timing in spec. Do you know how to adjust the timing?
2K jetta gl tdi 5spd 401k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old March 29th, 2015, 16:46   #3
terrydtdi
terrydtdi's Avatar
Also make sure you are pulling up the right engine and model year when checking timing in VCDS.
Old March 29th, 2015, 17:59   #4
jettawreck
jettawreck's Avatar
Air leak indicated by the air bubbles going to the IP can make for long cranking poor starts when the car has been sitting for any length of time.
Get the timing dialed in and probably seriously consider doing the TB service. If you don't have ironclad documentation it was done at the proper interval and properly it needs to be replaced ASAP. Take no chances with it.
The other codes seem to indicate there may be some issue(s) with boost control. Sort out the other things first and clear the codes to see what comes back.
2004 Cadillac SLS (wife's)
Old March 29th, 2015, 18:03   #5
1gcrazy
TDI(s): TDI
When I pulled timing with vcds, as soon as I clicked go with 000, it sputtered badly. Idle was hunting from 800-1000 and white smoke was coming out pretty good. It looked like I was seafoaming a gas engine. Not sure if yall sea foam the tdi's... Anywho, the change in the motor kind of freaked me out. Wasn't sure if I could do any damage or not by letting it idle while I fumbled aroubd with Vagcom so I rushed through it.
I did click the model with the ALH but not sure if I clicked the correct one since I saw two. Like I said, was in a hurry but I figured since the engine code was the same it wouldn't matter too much. I did try both and got the same result. Maybe I'll retry later tonight.
Old March 29th, 2015, 19:19   #6
terrydtdi
terrydtdi's Avatar
I believe you will want to select the second ALH option down. Since the timing is so far off and while your at it, do a good inspection on the TB components that you can see. One thing of importance is, there is a small metal tab on the back side of the tensioner, you might need a mirror, but check to make sure the tab on the back side of the tensioner is in the slot behind the tensioner. The belt should be very snug.
Old March 29th, 2015, 19:38   #7
Alchemist
TDI(s): '04 Golf
When you put the engine into basic settings, it chugged and sputtered because the computer was no longer trying to compensate for poor mechanical adjustment.
Check the timing with the lock down tools to be sure the mechanical part is right, then fine tune it using VCDS.
As soon as you get it running properly, change the timing belt system! Neglect here will bite hard and hurt a lot.
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old March 29th, 2015, 19:54   #8
whitedog
Yep. Get the timing sorted then look into the boost control deviation. Check that the turbo actuator moves freely when vacuum is applied. It should start moving at about 3-4 inches vacuum and hit the stop at 18 inches then hold there.
Old March 29th, 2015, 23:45   #9
1gcrazy
TDI(s): TDI
Whoops.
Old March 30th, 2015, 04:05   #10
Alchemist
TDI(s): '04 Golf
Change of plan.
Do the timing belt now. Do not start it.
Old March 30th, 2015, 06:32   #11
whitedog
Good call Terry. At least they turned it the right direction when tensioning it.
Old April 1st, 2015, 08:35   #12
Curious Chris
Fuel Economy: 47/42/38
And when the engine almost stalls when you go to Basic settings that is always a bad sign.
X2 on do not drive change timing belt.
Curious Chris is offline   Reply With Quote
Old April 1st, 2015, 09:02   #13
UhOh
UhOh's Avatar
Can you elaborate on what is happening in this circumstance? I'm not familiar with VCDS (still waiting on funds to purchase).
Old April 1st, 2015, 09:13   #14
whitedog
When the engine is running, the computer has control over the timing. When you put it in Basic Settings, you take computer control away from the timing and it runs on mechanical timing. When the mechanical timing is set right, when you put it in Basic Settings, you don't hear the engine change because the timing is where it should be.
Old April 1st, 2015, 18:40   #15
jettawreck
jettawreck's Avatar
And the reason the engine needs the mechanical (static) injection timing set correctly, even though it is computer controlled when running, is that during the starting process it relies on the mechanical timing up until it is running enough for the ECU to take over that duty. So it has to be set very closely to spec.
2004 GLS TDI Passat AC takes forever to kick on prometheum VW B5 Passat TDIs 3 July 5th, 2014 13:22
Running rough on Start up justintime_3 VW MKIV-A4 TDIs (VE and PD) 2 September 17th, 2012 07:35
replaced fuel filter now car takes forever to start. Bdpprocessors VW MKIV-A4 TDIs (VE and PD) 7 February 11th, 2011 16:33
Rough Running On Warm Start dlu VW MKIV-A4 TDIs (VE and PD) 8 May 21st, 2010 18:26
engine takes forever to warm up cooguyfish TDI 101 7 February 25th, 2010 19:55
Page generated in 0.15656 seconds with 11 queries
[Output: 127.77 Kb. compressed to 106.35 Kb. by saving 21.42 Kb. (16.76%)]
