Mako
- Joined
- Apr 4, 2011
- Location
- Cape Town
- TDI
- AMFPolo 1.4 TDI 100%Biodiesel, AHF Golf TDI 100% Biodiesel, AHF Golf TDI Wagon 100% Biodiesel, VW Syncro 3CT Kombi 100% Biodiesel, Corsa 1.7D 100% Biodiesel
2003 Mk4 AHF. Something odd is going on with the QA. (car is 300 miles away so working on it as I go back and forth)
Problem started with the engine cutting out after a few seconds when starting. Initially I thought it was an immo problem (no spare key to test with) so I deleted the immo. Tested the deleted immo ecu by running it in another AHF and all was fine there. But the cut out after a few seconds persisted in the problem AHF. I then stripped and cleaned the QA including cutting and soldering the joints that have to be cut to open up all the way. No difference. I've brought the suspect QA home and fitted it to my AHF Wagon and it runs but the timing goes full advance and while it does idle it cannot be driven safely. Reverting to the other QA and the problem goes away so this points to a faulty QA. In a day or two I'll head back to the stranded AHF taking my wagon QA to fit and test. (Might take the whole IP just in case)
Both QA coils ohm out with the same readings . Both respond in the same way when the ignition is cycled on and off and both are easy to adjust to set the voltage (.680 volts) when setting up for a first start. IQ cannot be set on the problem car as the motor doesn't run for long enough but its set to the scribed marks made before dismantling.
Faults:
G149 modulating piston (timing) Electrical malfunction-intermittent.
QA N146 Lower limit reached.
The faults follow the faulty QA from vehicle to vehicle. I'm curious as to how the QA alters or affects the timing as there seems to be no direct connection. In other words how does the faulty QA cause the idle SOI to go to full advance? (35 degrees BTDC)
Faults:
