AntonvBosch
Hi all I have a 2005 R5 TDI Treg. (217 000Km)
Had a failure on nr 5 cylinder with a crack in the block as well, also in the nr 5 chamber.
Engin has been reconditioned (sleeved etc..), all spares from VW agents.
5 New pistons, bearings etc.
New clutch kid.
No enginering work done on crank or camshaft, wear is still in spec.
Engin starts normal, but at idle it has a vibration coming from engin and one feels it trought the body, steering wheel etc.
When switching off engin, it stops immediately no irratic idling, just the vibration.
From the 5 injectors, 3 where replaced with new once, and coded etc.
What else can possibly cause the vibration
New clutch kid.
