Fastbird
I'm not finding much on the forums. At 225K when I removed my turbo, three studs came with the nuts. None are in what I'd call fantastic shape.
Comparing to the ID Parts replacements studs, I found an ARP stud set, part number 400-8014 at Summit for $89, that are 51mm long, M8x1.25 thread, 12pt nuts and washers. I've personally used a similar set on the turbo manifolds on my Corvette and they've done perfectly fine in a much more severe duty application.
Just curious if there's any other options as I'm probably not going to reuse the high mileage stock ones at this point.
