I'm considering buying an 02 Beetle TDI with manual transmission and 200k miles for $500. The owner says it was his daily driver. Recently he started it up and just as he was getting on the highway, the car died on him. It acted as though it wasn't getting fuel. It does turn over, timing belt is in place, and doesn't sound like any engine damage like bent valves or anything harsh. He cracked the fuel lines and it is getting fuel.
The check engine light gives these 3 codes
P0402 exhaust gas recirculation flow excessive
P0228 throttle /pedal position sensor / switch C circuit high
P1248 injecting start control deviation
On own 2 other TDIs and have done some work on them (replaced camshaft, timing belt, etc...) so I'm pretty sure I'm capable of fixing it IF I know what to fix. I do have a vagcom.
Please share your thoughts and opinions. What do you think it is? Anything... Where would you start? Is it reasonably fixable?
