I have no Idea, just another BS thing that my TDI is doing again. It has a sharp turbo whine when shifted from 1st-2nd then from 2nd-3rd. No whine or whitsle after. It all started after the odemeter Rolled itself back.
None of these cars have BOV's (unless aftermarket) the sound he was describing is the sudden drop of drive pressure you hear with a straight pipe exhaust. Have you checked your EGR tubes for cracks or sooty buildup? They will make a sharp whistling noise if they leak.It's not a blow off valve. It's an auto. It happens while it is shifting itself
