Ok, so I finally took it to AutoZone and had them run the diagnostics.
These are the codes they told me:
1441, 0402.
This is what the printout says:
The PCM has determined that there is excessive flow in the exhaust gas recirculation system. (For code 0402)
The ECM has detected vacuum flow to the Fuel Tank Pressure (FTP) sensor during a system sealed condition. (For code 1441)
Any help would be appreciated, since I don't have a throttle body!
By the way, I don't know if it matters, but every now and then, the check engine light either turns off or doesn't come on. In fact, after I picked up my car from the shop that told me I needed a new throttle body, the light didn't come on for two days. So I hurried and had my emissions tested (because it was due) and passed.
Thanks again!
Adrian
