So I had the injectors out to clean them, as I figured would be good to help tune up the car.. well as I took them apart I may have misplaced a washer or something because it seems like no fuel is being injected. I even took pictures and took it one injector at a time.. I also did a fuel filter change and did the normal procedure.. filled the filter full of diesel. I tried cranking the engine for at least 10 minutes.. but all I got was a couple burps.. I cracked all four fuel lines and cranked for a long time to let any air out but that did nothing but spray fuel all over the engine bay.. so I was curious if maybe someone had a diagram or anything to show exactly how the injector innards go together..
