Old October 6th, 2014, 12:01   #1
Asmerrill
Default What bulb is used in the fog light on the 2015 Golfs?
The dealer can't even tell me what bulb is used in there. Thanks.
Asmerrill is offline   Reply With Quote
Old October 7th, 2014, 10:25   #2
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
I believe it's an h11, I replaced mine but can't recall
Just pop off the housing cover and remove the holder
Takes literally 30 seconds
Sent from my SM-G900W8 using Tapatalk
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old October 7th, 2014, 11:00   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The dealer can't tell you, because ETKA only gives a VAG part number, and that is what they would use. Which is N-101-300-01. If you google that number, you'll find out what the SAE bulb designation number is.
oilhammer
www.cardocautomotive.com
Old October 7th, 2014, 11:33   #4
Asmerrill
I found out it is H11. Are you talking about the housing cover in the front or rear? Thanks!
Old October 7th, 2014, 11:52   #5
JASONP
JASONP's Avatar
There's a plastic cover in the front wheel well that goes over the bulb housing
Old October 7th, 2014, 13:00   #6
nkgagne
Fuel Economy: See Fuelly in signature
Are you guys blowing fog bulbs already, or just upgrading? I sure hope they aren't that flaky!
Bone stock. Dieselgate Stage 1 reflash complete.
nkgagne is offline   Reply With Quote
Old October 7th, 2014, 15:15   #7
Asmerrill
Just upgrading. I bought some LEDs to match the HID headlights.
Old October 9th, 2014, 09:46   #8
Asmerrill
Here is the difference. Matches the stock HIDs nicely.
Old October 9th, 2014, 13:34   #9
JASONP
JASONP's Avatar
Ok so what brand did you end up using? Looks good
Old October 9th, 2014, 13:37   #10
Korab
Fuel Economy: it had better be good
looks good! do you have have the lighting package or no?
Korab is offline   Reply With Quote
Old October 9th, 2014, 16:36   #11
Asmerrill
I do have the lighting package.
I bought the bulbs from www.gethidlights.com He also has an LED kit that will put out 3200 lumens.
Old May 20th, 2015, 11:07   #12
Saggio
Saggio's Avatar
Did you use H11 or H7?
I see H7 on the Sylvania bulb site.
Saggio is offline   Reply With Quote
Old May 21st, 2015, 10:34   #13
Asmerrill
I used H11. I think the H7 is similar and just has a different way of securing them. I'm just guessing.
Old May 23rd, 2015, 14:30   #14
deAutoLED.com
It is an H11 - we have a set that works great for your car - 4200 total lumens:
http://deautokey.com/product/new-de3...-2015-mk7-golf
What is great about our kit is you can turn it 360 degrees, this means you can point it in the best spot in your reflector housing, sometimes it is up/down other times it is side/by side depending on the VW housing.
Very simple to install - plug & play too
LEDs - Vinyls - Keys
www.deAutoKey.com
www.Facebook.com/deAutoKey -- Like us for a chance to win prizes!
deAutoLED.com is offline   Reply With Quote
Old May 24th, 2015, 14:35   #15
Asmerrill
Granted, I know it's the going rate, but $154 is too steep for me. Awesome output though.
Fog light bulb? surfbus VW MKIII-A3/B4 TDIs 5 August 4th, 2013 11:48
Xenon Match Fog Light Bulb H0mersimps0n VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 29 January 29th, 2013 12:57
Fog light bulb replacement? Coffeemade VW Passat Family (NMS and B7) TDIs (2012+) 11 September 20th, 2012 10:39
GLI rear fog light bulb Link977 Upgrades (non TDI Engine related) 2 March 3rd, 2008 10:28
fog light bulb problem chenyichung VW MKV-A5 Golf/Jettas 20 May 10th, 2006 18:25
Page generated in 0.14484 seconds with 11 queries
[Output: 121.99 Kb. compressed to 101.31 Kb. by saving 20.68 Kb. (16.95%)]
