SRHeer
If you can comment on following either with what you recommend or know and or maybe recomend someone else please let me know! Thanks for your time!
I am wanting to put a mTDI with Rover pump into a VW Mk1 Rabbit pickup. I see where some have cut out a spot in the lower (radiator) support for the AC compressor to fit while using the serpentine belt system however if possible I want to keep AC without cutting into right-hand side of bottom radiator support - can I machine out the Mk1 injection pump bracket to accommodate larger Rover pump hub nose and still have enough clearance for it to clear glow plugs and eng block and all behind? -
Doing away with the serpentine belt system would also do away with harmonic balancer so my next question is can I use the Mk1 or Mk2 pulley bracketry systems for alternator - AC compressor - and power steering?
And finally if I do the serpentine belt delete for AHU what timing belt and tensioner would I need to use? Can I use the Mk1 injection pump bracket and still use a 1.9 timing belt - maybe not because the injection pump bracket for 1.9s juts out farther than the 1.6s - Maybe a smaller or larger diameter tensioner would accommodate one or the other - or it might just best forget trying to save the lower front support frame and go ahead and cut a spot out - if it will be awkward or troublesome to get things to match up or work by trying to use Mk1/Mk2 systems on an AHU motor? Anyone try this or have any suggestions? Thanks
