Beaulanier
hmmmm, so is your point is the same as I was thinking....that the oil level in the pan is above the fitting on the bottom of the pan, and the fitting on the turbo is level with the fitting on the pan, so, the turbo drain is below the level of the oil?Beau, looking at your last picture, I would expect the oil level in the pan to match the oil level on the turbo side of the hose. A fluid will always seek it's own level.
What do I mean? Take a length of clear hose and fill it with water. Hold both ends, one in each hand. Note that the water level matches both ends of the hose even if you raise one end of the hose higher than the other. We used to use a method like this for leveling the scales with scaling the race car. We have a sweet laser level know that lets you level in about 5 mins.
I just finished installing my scavenger pump set up. when i disconnected that hose from the turbo, oil started flowing from the pan at that level.
not a good drain.
