jimbote
Certified Volkswagen Nut
got any pics of the PS pump restrictor you drilled?...the effort is a little high on my truck and I've considered opening the pump to see what I could modify for more flow.... what is your current clutch?
We are still waiting
the hole is on the slidegot any pics of the PS pump restrictor you drilled?...the effort is a little high on my truck and I've considered opening the pump to see what I could modify for more flow....
marlin and its a joke.......what is your current clutch?
In my build thread I posted info about these pumps with listings about Shim number vs. PSI that might help you, the article that the chart is for also talks about other aspects of the TC pump. It's post #87 on Page 6the hole is on the slide
take the line off
remove the large "nut" looking guy the banjo threads into
once thats loose
there is a spring inside and it will push the slide out
dont go crazy
TOO large and it kills the pump
Im playing the diameter game now
pumps 4-5+6 are in hand
Im gona try and take some PSI measurements with each pump
knowing the drill size for each pump
going to try and find a happy medium
while I save $ for full push-pull hyrdo system
Well it will see as much public roadway as woodsFull hydro or assist?
I too would love to see a picture of the hole you're drilling out. Is it under the pressure relief valve in the body or ?
Thanx,
Jaysin
That's what I was thinking! Belt breaks and your a gonnerWell it will see as much public roadway as woods
So im thinkn assisted
Full hydro on the road might not be the best idea...
Haha
i swear this is the engine toy minis should have come with!! ... this is yet another great build ....is that a vnt17?... if your still looking for a speed output solution you can use the tach signal as a surrogate conditioned with a dakota ... been that way on mine for over 35k .... thanks for the heads up on the pump ill go for the shimming method instead ... the marlin/tg clutches probably work fine for gasser apps but are quite a joke when it comes to diesel torque ... i went through several clutch combos (including a TG 1600lb) before i found a setup that would hold.... keep up the work and keep the videos rolling in !!Got about 300 miles on it now
Only thing I can say for sure
Is I ****n LOVE IT!!!!!
Disagree...i swear this is the engine toy minis should have come with !!
The reason the lines have to be the same length is that it takes time for pressure to build in the line before the injector pops. If one line is longer than the others then that injector will fire later. Basically you would have a lumpy engine with one cylinder running retarded.
I'm working on an '86 2wd pickup too. Good choice, that truck is pretty light.I'm ramping up to do one next year. Getting a 86 2wd. My 2000 jetta is rusting out badly in the rear. So I'm gathering as much info as possible. Was thinking about swapping the dash from the jetta not the truck.
The wiring looks awesome, interested in making simplifying another harness when the time comes?
Looks good man.
Nice work - yep, it just takes time. It's a fine machine once completed!MILAGE update::.....
5,500 miles and ZERO issues
LOVE this swap
Just wish I could get all the suspension bugs worked out.....
Does 60 with ease
runs out to 100 with no issues and would continue to pull but its a truck so thats enough for me
I find the 68-72 mph range to be my "happy spot"
nets me about 33/34 mpg loaded with camping gear
Now to add cruze control.....
FINALLY add the tacho (Been using obd2>wifi>Iphone for heads up display)
To those of you reading
this swap IS worth it if you take your time and do it right
Yes its a bit pricey but Im a HAPPY camper with my results
