CharlieT
Congrats !
6th is sweet, I agree, finally got my 6sp conversion to behave.
I'm in the process of doing an ecu swap, I noticed my Passat has those round pin body harness connectors. Do you know if any US cars have these? I'm going to make similar adapters with the round pin on one side and rectangular pin on the other. I have your docs saved and have one of my own started.
Sounds fun!I'm in the process of doing an ecu swap, I noticed my Passat has those round pin body harness connectors. Do you know if any US cars have these? I'm going to make similar adapters with the round pin on one side and rectangular pin on the other. I have your docs saved and have one of my own started.
So swap excuse for smog test? How will the vnt work with the us ecu?Yes, I'm using the stock cluster.
As for my smog ref, I got some problems
Turns out I need an egr cooler and US ecu... I totally thought the ahu didn't have a cooler :/
I'm going to see if I can fit the whole ahu intake/egr system, if I have that, I should pass, with a proper US ecu
