Scott_DeWitt
Doesn't the BHW have the A/C compressor on the drivers side?If not, I am screwed too, as I was planning to fit a 240mm DMF soon, with this exact starter !
No, the motor on the BHW and AVF starters are identical length. It is the aluminum output housing that is longer on the AVF, to house the larger bearing due to lack of end support for the shaft.The motor on it is also longer than the motor on the 5 speed one.
Maybe I can get a shorter motor, and swap it onto the 6 speed starter's little gearbox thingy?
No. Pass side. But I suspect it is a different AC compressor to the one on the AFN. I know it is a fixed displacement compressor on the BHW, which is kinda wierd for VW of this era. Maybe that makes it shorter.... fingers crossed.Doesn't the BHW have the A/C compressor on the drivers side?
Not sure if it matters but there was a tooth ring gear change in the later 2000 model years.Also, Mr. Demon_diesel over here: http://forums.tdiclub.com/showpost.php?p=4063805&postcount=95
Is using a starter with the part number: 03G 911 023
It LOOKS substantially shorter in comparison to my 6 speed starter?
Maybe I'll ask him to measure the length of the motor.
Tuesday,12,February,2013,21:39:59:13230
VCDS Version: Release 11.11.4
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 028 906 021 CE
Component and/or Version: 1.9l R4 EDC 20SG 0803
Software Coding: 00002
Work Shop Code: WSC 00083
VCID: 54A7C4E6A4C8E1B8D5D
8 Faults Found:
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
00532 - Supply Voltage B+
27-10 - Implausible Signal - Intermittent
00777 - Accelerator Position Sensor (G79)
01265 - Exhaust Gas Recirculation Valve (N18)
31-10 - Open or Short to Ground - Intermittent
01262 - Solenoid Valve for Boost Pressure Control (N75)
00527 - Intake Manifold Temperature Sensor (G72)
30-10 - Open or Short to Plus - Intermittent
01269 - Commencement of Injection Valve (N108)
01266 - Glow Plug Relay (J52)
Readiness: N/A
29-10 - Short to Ground - Intermittent
I am in Houston and have done this swap twice now, so shout if you need some help.I'm not a guru, but it looks as if you are on the right track to get this going. As I am talking to Frans about a kit also, I am very interested in seeing you get this done. I think I am going with a BHW and 6 spd to put into my 03 1.8T. Keep it up, looking good.
