GTiTDi
TDIClub Enthusiast, Macht Schnell! Vendor , w/Busi
- Joined
- Oct 18, 2010
- TDI
- '91 GTI CJAA swap,'02 Jetta wagon ALH swap, '03 GTI 1.8T rally car, '03 Sprinter 3500
I used B4 upper airbox pieces to make my hybrid A2/B4 box
I am running the MK3 cluster - just hacked out the stock MKII cluster supports. Not pretty - but it works.Thanks man likewise! Nice choice of car! I actually have some questions for you regarding lifted Mk2's, I saved the B4 TDI suspension with this in mind, although for my Jetta Coupe..
The Passat pedal assembly is nearly identical to the mk2 assembly minus the fact that it is dbw and hydraulic clutch release. There was only one stud that I had to add to the Mk2 firewall in order to have it bolted in 100%. Oh I had to tweak the slot at the end of the column and egg the column mounting holes but other than that it fit perfectly.
What did you use for a cluster? I still have to upload a lot of pictures, modified mk2 cluster bezel included..I have been too busy having fun this summer!
i cant stand the whole "hella flush" stanced dubs trend..broken oil pans are not a badge of honor! I like rally cars better so there you go!
cool, thanks Frank. Going to re-use the stock rods, and check the aim of the squirters..I have already dressed the lips at the top of my borestake a look at this thread before you drop the pistons in:
http://forums.tdiclub.com/showthread.php?t=210044
Thanks! I have been trying not to spend too much money on this project, but that is much harder than I thought...I love your build, i basically left my motor stock for now, getting it to fit and making everything fit was first, i will spend money on the motor when i finish my build, money goes like water and it seems my bank account seems to always have zero in it....great job keep it going
Thanks Larry!Hi GTiTDi,
I discovered your thread and was really impressed with your project! I live in Rockport and have a place in Marstons Mills. Perhaps we could get together sometime. I have a rather stock 2000 TDI Golf that I love. I commute to Wilmington during the week and enjoy the 50ish mileage. I also enjoy working on my car, but when I get stomped, there's Keith Harley in Chelmsford for help.
Happy Motoring!
Larry
P.S. Love the pretty girl clinging to the VW emblem!
Well after quite a hiatus, I finally uploaded some shots of my modfified mk2 cluster bezel. The mk3 cluster fits nicely in a mk2 dash with the right modifications. Done wrong and they look like scheisse. The solution is often just doing a mk3 dash swap, but unless you have a mk2 with power windows it isn't a viable option. I like to be able to roll my windows up and down with the door shut. Most mk3 dash installs don't allow enough clearance for the cranks!I still have to upload a lot of pictures, modified mk2 cluster bezel included..
I don't want to take the fun away from figuring it out!Good looking job!
How about more details of the glovebox to dash adapter? That would be a timesaver for those of us who'd rather follow your example than reinvent the adapter!
I looked at the bottom picture a little more… Did you just extend the shell? By how much?
Does this mean that the cluster fits deeper into the dash than the Mk2 cluster fits? If so, how much deeper?
Many thanks!
OK, OK, I'll dangle the gold bug from the limb of the oak tree by the light of a 3/4 moon…I don't want to take the fun away from figuring it out!
It is clear what needs to be done when you start fitting it up, start by removing the mounting points for the mk2 cluster, and then fit in the mk3 cluster to see where to start trimming. The mk2 bezel needs to be widened and extended as not to block the edges of the mk3 cluster.OK, OK, I'll dangle the gold bug from the limb of the oak tree by the light of a 3/4 moon…
BTW nice Poe reference!OK, OK, I'll dangle the gold bug from the limb of the oak tree by the light of a 3/4 moon…
Yes the stock inter cooler setup is only suitable for stock power levels. It was kind of a waste of time to modify the fender to install the side mount. I should have gone with a front mount from the beginning, but this has been quite the learning experience!got any pics of your Saab intercooler setup?
I take it this replaced the stock B4/mk3 IC?
