Here are the symptoms:
- Interior lights go on/off randomly
- Alarm goes off when car is unlocked
- Dashboard indicator indicates trunk/door ajar when everything is closed
- Warning bell/buzzer stays on after starting car for at least 3 minutes
- When headlights are turned on, the bell/buzzer goes off
- The trunk will not unlock with the key
- The keyfob does not unlock the doors when pressed
Here is the VAG-COM output:
Sunday,29,June,2008,17:16:39:11973
VCDS Version: Release 805.0
Data version: 20080625
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 3VWRP69M02M010715 Mileage: 247110km/153547miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G400AG 4102
Coding: 00001
Shop #: WSC 00066
3VWRP69M02M010715 VWZ7Z0A3836559
2 Faults Found:
16786 - EGR System: Excessive Flow
P0402 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 KT
Component: AG4 Getriebe 01M 4891
Coding: 00000
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 M
Component: KOMBI+WEGFAHRSP VDO V58
Coding: 07232
Shop #: WSC 00000
2 Faults Found:
01176 - Key
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901.lbl
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
Address 35: Centr. Locks Labels:
Note: Excessive Comm Errors
End ---------------------------------------------------------------------
Clearly from the VAG-COM it looks like the central locks controller has a problem. Any ideas? I hate to replace it without diagnosing further. Any idea where the central locks controller is physically located? If I knew where it was I could check the external connections for loose connections, loose wires, etc.
Any help would be appreciated. Thanks.
-Jeff
76
Coding: 00001
Shop #: WSC 00066
2 Faults Found:
Coding: 00000
Shop #: WSC 00000
Coding: 0004097
Coding: 12340
Shop #: WSC 00066
1 Fault Found:
Coding: 07232
Shop #: WSC 00000
2 Faults Found:
01176 - Key
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
-Jeff
