toyota swap
lews930
tampa,florida
96 passat
The engine tuner worked!!!
Revs all the way to the top
Jimbote, thank you but I won't need Bruce's help.
I'll post video on YouTube as soon as I get her all buttoned up
lews930
tampa,florida
96 passat
Power isn't bad. It feels like my old 22r toyota. You just don't have to rev the **** out of it.
I'd like to say thank you to all that had input in my build
THANK YOU
now to get the a.c. working and get tho he tidied up
Btw I have a V6 slice if anyone wants to borrow it. R150
papasmurf
Orlando
1997 jetta tdi, 2004 passat sedan tdi, 2005 passat wagon tdi , 2005 passat sedan tdi
might take you up on that offer lews930
lews930
tampa,florida
96 passat
Update: got the pump timed via vcds. Runs great.
Then Got a chip for the ahu computer from Frankenyota. Thanks Ernie.
It really moves out! Gonna be fun to drive
lews930
tampa,florida
96 passat
Oil pressure gauge not working. I've tested the gauge for proper resistance (25 ohms). It will work if I ground the wire to the block.
I've used both idiot light senders and gauge senders and still no working gauge.
Btw I have oil going to the turbo
Any ideas?
I'd like keep stock looking
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
mechanical gauge test to make sure your developing actual pressure ... you can test your current setup by putting regulated air pressure to the removed sending unit and observing the key on gauge performance
smelly621
Sonoma County, CA
2001 Golf, 2003 Tacoma
I killed my original oil pressure gauge sender pretty quick when it was mounted directly to the housing. According to an Autometer document I found they don't like high vibrations.
Remote mounted now with a braided line.
Could it also be thread tape on the sender body preventing you from getting a good ground?
