sptsailing
- Joined
- Jul 9, 2010
- Location
- Safety Harbor, FL
- TDI
- 2006 Jetta Manual, stock with Panzer Plate & Franko6 modified EGR cooler & CAM
So at 147,000 miles, the original camshaft in my 06 BRM Jetta finally got bad enough that I heard the telltale bad cam engine sound. I am in the middle of replacing and repairing not only that, but several other things as well, but am now wondering where all the metal no longer on the camshaft went.
Some have said it all went into the oil filter, but I got curious, and with the cam and rockers off, I stuck a couple small magnets into whatever pools of oil I could see in the head. Bingo, iron shaving came up. I have a magnetic drain plug, and of course, it had some as well, but there is a huge percentage of cam wear metal unaccounted for. Where else might I look for more in the head? The valve cover and oil pan are both still removed, is there some way to clean out wherever these shavings might be hiding? Is it worth removing the head in order to insure there are no more shavings that will cause future problems? I pulled off the oil pan and much to my surprise, did not find any shavings there at all. (I have only ever run the specified Pentosin oil, with changes at or less than 10k miles.)
It has not occurred to me until now that I perhaps should have been checking all my oil filters for metallic iron. That might have let me know to have checked my cam prior to it wearing a hole in one of the exhaust lifters.
Per Franko6's suggestion, my refurbishment is including an oil pump replacement. Sure enough, the original oil pump had some scoring on all of the expected surfaces, but it still actually looked pretty good.
