Hey vwz,
2005 Jetta GLS, like your Passat but a few inches shorter. BEW engine. I have never been back to the dealer, so I am assuming that it is the as-built ECU software version, which I believe was 7 volt. I am just surprised to see such a wide range of prices for the NGK part. $11 only makes sense (to me) if there is excess stock out there and sellers are trying to move them--or there are low quality fakes out there being sold. So that is my first question, is $11 for this part reasonable in 2023 or steer clear?
I believe the NGK 7 volt is the correct drop-in replacement part for the original 7 volt ceramic. My second question is whether I should just leave the original as-built GPs in there, or try to gently get them threaded out and replaced. I see information out there that they are fragile and can break off in the engine, and that they are fragile and can break off during removal. This state is in some ways a metaphor for other parts of my life these days.
Right now, starting the car, there are no GP error codes. I am assuming the intermittent GP error codes would be traceable to a bad harness, and that an always GP error code upon starting means a bad GP
carpet removal tampa. So that is another question, can GPs themselves throw intermittent error codes like I have seen for the past five years?
