db123
So I cleaned up the mating surface of the oil pan and block real well, put my 3mm bead of Reinzosil on the pan, bolted her up and then got to the final two bolts at the back of the pan, the ones that go through the bellhousing. So I've got the jack suppporting the subframe, the car on ramps and I start to get claustrophobic, panic sets in and I have to bail. I try going at it from a different angle, but I can't see the threaded hole, the bolt falls off the 5mm ball end allen socket and now it's down into the bellhousing. I could feel it, but have pushed it in further.
So now I have two problems, how do I get that bolt out of the bellhousing and now the rtv has cured and I don't have those two bolts installed and torqued.
I think I can get a small magnet on some kind of flexible do-dad to pull the bolt out, I hope.
Can I just install these two bolts once the subframe is bolted up without any leaks and is there a trick to getting those bolts up there without them falling off the wrench?
