Chaput87
Just in first gear. If I press the accelerator more than 1/3-1/2 of the way down, when it gets to about 2500 RPM's or so the engine seems like it "cuts fuel"
Runs fine other than that. Just had a new cam/lifter set put in with a new MAF. I am at 230K. I can give it full throttle in any other gear and it doesn't have a problem. When it starts cutting out if you keep your foot on the accelerator it just continues to decelerate. As soon as you let up it returns to normal.
I have been searching and trying to figure out if anyone else has had this problem but I couldn't find anything. I was thinking the fuel filter needs replaced but it should act up more in a higher gear under load if that's the case I would think.
Any Ideas?
Any Ideas?
