Hi all,
Okay here goes. Drove the Jetta to work on Tuesday with no problem although she did hesitate when I first started her in the morning. Attempted to start her later that morning and nothing. Engine turns over but won't light off. Tried cranking her several times for several seconds and finally got a CEL with flashing glow plug and oil lights. Scan tool downloaded a "no engine RPM sensor voltage" fault. After researching the fault online figured the fault was caused by cranking the engine for so long without it starting. So I reset the fault. Left car at work and next day started troubleshooting fuel malfunction. A little history - got rear ended a couple of months ago. Damage repaired within a week but noticed a whine coming from the rear passenger area after about a week. Assumed it was something rubbing on the tire after repair because I could only hear the whine when the car was moving above 25mph. Did a little more fuel troubleshooting and isolated problem to a bad lift pump (no sound from pump when ignition turned on). Replaced pump and now sounds coming from pump, fuel being pumped out of filter lines but engine still will not light off. Battery is pretty much dead so I'm gonna throw it on the charger tonight and try again in the AM. Any suggestions? Do you guys think the engine fuel lines are full of air? Is there some type of purge procedure? Could my problem be electrical now? Thanks in advance.
