had a cel come up on my car it's a throttle position sensor problem, anyone have problems with this? don;t ave the fault code right now, but I did change my battery a while back....
The throttle position sensor IS part of the pedal and you have to change the whole thing. Easy job 3 nuts and a wire connector to remove. About 80$ from Impex.
