2012 jetta sportwagen TDI with a KEYED ignition.
Situation: Engine starts then immediately stalls out. "Key not in range" is on the display, though no other indication of "anti-theft" or anti-theft icon displayed. It is NOT a keyless ignition. I use a key to start my car.
Background: 1.5 months ago began running a blend of 20% biodiesel (B20). No identifiable problem, figured I'd have a fuel filter change in the near future. 2 weeks ago (hate to admit it) I ran a blend of 50% kerosene, 30% diesel, 20% B99. At this point probably one full tank of that mix has gone through with no apparent problems.
Recently somehow my "lights are on", "key's left in the ignition" audible alarms turned off suddenly. I left my lights on by accident and the battery drained. I jumped the car, placed a trickle charger on it, I get 11.9 volts via multimeter now. I "reset factory setting" through settings function on the display.
Next day (?, could have been 24 hours later), I go to start car on 18 F morning, I get the engine starts immediately cuts off. I figured it was fuel filter. I changed the fuel filter amateur-style with no software to flush my fuel lines, just topped off the filter and canister with new fuel and was careful not to drain fuel from the lines while they were disconnected. Still have the same problem.
A locksmith came out and assessed my key functions/antenna/etc, said everything works right but didn't think "re-programming" my key would do anything to help me. I'm not sure why he figured that.
I've tried the witchcraft tips of touching the battery leads together for 20 seconds, locking the car/opening it manually, leaving the key in accessory for greater than 1 hour with a trickle charger connected, changed the battery in the key. Nothing has changed the issue.
Questions:
If it's the anti-theft activation, would I get a display that clearly says that as opposed to the "key not in range"?
What's up with the "key not in range"? Is that the most suspicious thing?
Did I F my car up by running ONE tank of 50% blended kerosene through it?
Air bound?? I can't imagine, the exact problem was happening before the fuel filter change and same problem afterwards. The engine has only ever "ran" for about 1 second or less any time I've tried starting since the original problem.
Questions:
