aisamim
Hi everyone,
I posted here just over a month ago in regards to a possible HPFP failure. After I replaced the HPFP, cambelt, cleaned out the fuel system etc, the cars been running sweet, having done almost 2k miles in the past couple of weeks.
I noticed the car was doing a DPF regen as i shut the car off earlier, so I just went home and attempted to use my VAG401 xtool to manually force a regen to ensure its completed. But as I plugged the scanner in I just scanned for codes out of curiosity and the following code popped up
P106500 - Fuel Pressure Regulation
Control Difference passive/abiogenesis.
I havent had any issues with the car running and I'm just wondering whether theres an underlying fault, even though I drive it a lot and it hasnt given me any problems since I repaired it.
Have any of you had a similar code pop up?
