VCDS trouble after emission fix
dtreid
Alberta, CANADA
2015 Passat TDI 128k km
Just got the emission fix one on my Passat TDI.
Tried to get into the engine with VCDS and I can access anything except fault codes. I'm using version 12 of VCDS.
Any other ideas or are we locked out by VW now?
JSWTDI09
Las Vegas, Nevada
3 questions:
1) You "can access anything except fault codes" or you "can't access anything except fault codes"?
2) Is there a reason why you are still running an old version of VCDS? The current version is 17.8. This may (or may not) make a difference.
3) Does it list a label file for your engine controller or does it say "none"?
Have Fun!
Don
740GLE
NH
Every time I fire up VCDS there seems to be an update and wants to force it. Don't resist updates!
