richbking
- Joined
- Jul 19, 2006
I had taken my jetta to the dealership twice because every time it rained the floor behind the drivers seat would become wet. Each time the dealer said they could not replicate the problem.
Anyway after wasting my time with the dealer I decided to fix it myself. In 15 mins. I was able to locate the problem and then it took me about 3 hours to fix it. I followed the DIY that someone had done for the MKIV.
http://forums.vwvortex.com/zerothread?id=2115848
I just wanted to give you guys a heads up that the tubing needed to do this DIY needs to be 1/2" ID and 5/8" OD, because 3/4" OD called out for the MVIV DIY will not fit through the pillar that is used for the existing rear drain tube. The 5/8" OD tubing barely fits, but solves the problem.
