ruking
- Joined
- Mar 27, 2003
- Location
- San Jose area, CA
- TDI
- 2003 VW Jetta, 5 M, Reflex Silver: 09 Jetta, 6 Sp DSG, Candy White: 12 VW Touareg, 8 Sp A/T, Flint Gray
Actually per my own post, I actually follow my own advice for ...gassers. Because of the superior design (but butt ugly )of the VW diesel air filter/box and the difference in the way it functions, I would not significantly extend the gassers air filter change cycles. ( I run 60,000 miles with a recommended 30,000 miles Honda Civic intervals) I do run 20,000 miles OCI's on all my gassers.A lot of what you say goes for gassers as well. My Scion was supposed tom have a 5,000 mile OCI, but they updated it to 10,000 miles. Oil analysis ( I use Blackstone) shows that the oil still has quute a way to go at the 10,000 mile mark, and I do a lot of towing too!
Air filters and oil filters are similar. There's not even a recommended interval for changing then fuel filter on my Scion.
Also, many gassers (Scion/Toyota included) are using timing chains these days. Most of them are good for 250,000 miles or so.
Comparing spark plugs to glow plugs is kind of odd. They don't do the same thing at all. There are some gassers that need spark plugs every 25,000 to 35,000 miles, but there are also spark plugs that last more than 100,000 miles. Glow plugs can last well over 100,000 miles too... But they tend to be more like incandescent light bulbs -- they burn out. Sometimes for no obvious reason. My TDI needed one glow plug at around 70,000 miles. The others lasted more than twice as long (they are still working). Some people experience a glow plug failure at 20,000 miles. They are highly variable, and are not a regular maintenance item.
I think if anything, reading these current threads has me thinking along the lines of going from 25,000 miles OCI's to 30,000 miles on the TDI's. Time to break loose from the belt and suspenders mentality.
