The Escape hybrids like to eat the electric steering column assemblies, though. As well as A/C compressors. We do a LOT of those. Those two items alone negate any fuel savings (along with the higher purchase price) over a regular Escape if they fail.
Here is the steering column I did just recently:
We service a fleet of security vehicles that are mostly Escape hybrids. I find them to be pretty crappy vehicles myself. They've been purging their fleet of them and replacing them with Prius Cs, which are far better... but still excessively priced considering what they are and what they do. They could have saved ~$8k on each C and bought a Yaris instead that would work just as well.
The other goofy thing about those Escapes is that Ford chose to use the A/C system to regulate/control the battery temp. So they run lines with an extra expansion valve to the rear of the car, which in itself isn't really any different than most other vehicles with rear A/C systems, however... Ford uses a compressor that is belt driven off the engine. Which means, in order for it to work, the engine must be running. So if the battery temp goes up, the engine must run. But if the engine is running, the battery doesn't need to be used. It is sort of an oxymoron of operation. And Ford's compressors use an RCV that fails, similar to the ones in Volkswagens, only in the Ford style, the RCV piston rides directly in the compressor bore, and that usually gets worn out too. So a new RCV may only restore the compressor's ability to work to maybe only 80%, and only for a little while (like maybe a season), before they start acting up again. Dumb.
Of course, that was the previous Escape. The new Escape is a whole new level of problems that I cannot even describe. Ford clearly rushed that thing to market, the TSB list is more like a book, and reflashes come out so quickly for them you'd almost need to check weekly.
