Ran across this while getting info on the DMF and how a finger can rub against the bellhousing.
https://www.youtube.com/watch?v=P-qghjeDS_Q
How many owners do you really think have their dmf tested for wear? Oh, and in the case of the video, you are lucky since you don't have to remove it to test it. You only have to pay through the nose to drop the trans to get to it.
Probably explains why there are so many failures of the system.
I guess with the dmf, clutch assy life is between 30,000-50,000 miles. Yea, that is a real improvement over the smf.
Also keep in mind that CAT has been putting tons of torque through drivelines for years without using dmf's. Granted the hb was pretty stout. The statement in the video that the new engines require the dmf.....sounds like marketing bs to me.
