Old March 10th, 2014, 10:32   #1
PacketHauler
PacketHauler's Avatar
Default First TDI Road Trip Planning
Hey everyone,
I might have to travel for work this weekend, and I've never had either of my TDIs out of the state of MN yet. This means unknowns with bio-diesel content, etc. I plan on carrying a grey bottle of the PowerService additive since the temps will be above 30 for the whole trip. The route I'll be taking will mostly be US highway as that is the most direct route to St. Louis, MO. I should only have to fill once or twice for the whole trip.
Since I'll be using PowerService, does it really matter where I'll fill up, as long as they sell diesel and are on the main route?
PacketHauler is offline   Reply With Quote
Old March 10th, 2014, 10:41   #2
TDI smile
TDI smile's Avatar
Location: Edmonton, Alberta (b4 BC - LOWER MAINLAND = Chilliwack)
You always find a DIESEL pump. Lots of Truck Stops. You should have no problem in keeping your Tank FULL. Have a safe trip and save.
TDI smile is offline   Reply With Quote
Old March 10th, 2014, 11:23   #3
Only problem you might have is finding a pump with the right filler neck, if you have the fuel restrictor. Don't go to truck pumps. I've found that even on places like the Ohio Turnpike it can be difficult to find the smaller nozzles.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old March 10th, 2014, 11:41   #4
mrcowden
Originally Posted by PacketHauler View Post
Hey everyone,
No, it won't matter where you fill up, as long as it's ULSD and a compatible nozzle. Your car doesn't need the PowerService, but if it makes you feel better, it's your money.
mrcowden is offline   Reply With Quote
Old March 10th, 2014, 12:21   #5
PacketHauler
It's more for a lubricity additive than anything. I don't use additive here in MN because of the B5 mandate.
Old March 10th, 2014, 12:21   #6
TDI smile
TDI smile's Avatar
Most Truck Stops have a pump with CAR Hose.
Old March 10th, 2014, 16:02   #7
Not that I've found in the US. In fact, many car pumps in Ohio/Michigan/NY/PA don't have the smaller nozzle. My usual station here in MA doesn't either.
Old March 10th, 2014, 19:24   #8
PacketHauler
This is good stuff to figure out before the big road trip to Florida later this year.
Are there certain brand of truck stops that tend to have car pumps as well? Or is that hit or miss?
Old March 10th, 2014, 19:44   #9
TDiSkater
Fuel Economy: 35 Winter/41 Summer
I've fueled in IL/WI/MN/IN/MI/KY and never had an issue once with a truck nozzle. I need to get out of the Midwest.
VW-OEM European Steel Skidplate | 35% LLumar Tint all around | Pano Sunroof | ScanGauge II | WeatherTech Weatherflectors and Digital Fit Floorliners l Faux TDI Mirror Etching l RGM Bumper Guard | Conti PureContact | Non-OEM Aspherical Mirrors - $3 Blind Spot Mirror | 70,000 miles |
TDiSkater is offline   Reply With Quote
Old March 10th, 2014, 20:24   #10
PacketHauler
I haven't tried to put a truck nozzle in the JSW yet. It doesn't have the mis-fuel guard installed. Just the obnoxious warning label around the filler neck in case I forget it needs diesel.
Old March 10th, 2014, 20:37   #11
TDiSkater
I tried once to use a high flow truck nozzle, actually twice (before the misfuel restrictor was installed). If you find one, It will make you laugh as it's big and will not fit (restrictor or not). Luckily these were dual diesel pumps, so I just picked up the other hose with the auto nozzle.
Old March 10th, 2014, 20:48   #12
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
I doubt that you'll have any issues in your travels finding the right pumps. Remember that you're going across farm land where a lot of the pickups are diesel and have to be filled somewhere. If in doubt, just ask the attendant. They should know which pumps have a car nozzle.
Best route recommendation is 35 south to US20 east. Pick up I380 outside of Waterloo. It will turn into Iowa 218 south of Iowa City. Once you cross the Missouri line, it turns into US 65 and runs right into St Louis. Some where near St Louis, you'll run through oil hammers area.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
kjclow is offline   Reply With Quote
Old March 10th, 2014, 20:48   #13
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
If you stop at a truck stop, go to the CAR side of the truck stop. IF they have diesel on the CAR side, they should also have CAR SIZED fuel pump nozzles.
I have never had a problem finding car sized nozzles anywhere in the midwest and southwest USA.
MO,IA,KS,AR,NM,AZ,NV,OK,TX,ND,SD,WY,NE,CO,UT,IL,OH . And several other states I have surely overlooked.
Fill up when your car has half a tank left so that you have a 300 mile range left to 'find' the right station. I am sure you will find a good reason to stop earlier, I always do...
Have a great trip, things will be fine!!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old March 11th, 2014, 09:14   #14
PacketHauler
My route is almost identical to that, except I usually pick up US 18 just outside of Mason City. It's 4 lane, 65 MPH highway all the way down to Waterloo and kinda goes in a diagonal line after Charles City towards Waterloo.
Old March 11th, 2014, 09:19   #15
PacketHauler
And now that I look at that route on Google, US 20 makes more sense, since you bypass that 30 MPH portion of Waterloo on 218 with the stop lights. Good call.
Planning road trip from Ottawa to Kissimmee Fl. GuyGuy Road Trips 16 August 25th, 2013 13:01
Planning road trip to Seattle area. All of Us Road Trips 8 February 4th, 2010 19:10
West coast road trip (planning stage); Any suggestions ? jeepescu Road Trips 2 April 18th, 2008 10:03
Planning a road trip Atlanta to Shiocton,WI lost1wing Road Trips 0 October 18th, 2007 18:11
Planning a road trip in July - need advice Octang Frye VW MKV-A5 Golf/Jettas 4 May 6th, 2007 08:43
Page generated in 0.18624 seconds with 11 queries
[Output: 135.84 Kb. compressed to 114.06 Kb. by saving 21.78 Kb. (16.03%)]
