Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old May 13th, 2010, 16:35   #1
Spulen81
Default FS: A3/B4 ECU metal case "JB"
I have a stock ecu from a 1998 Jetta TDI in good working order. Its part#028 906 021 JB
$200 shipped in the US.
-1986 Jetta Coupe, AHU, R520s,Alligator 3 bar, D24 manifold, GT2052 - SOLD
-1986 4Runner TDI - SOLD
-1991 GTI-TDI - SOLD
-2011 Golf TDI - GONE
Spulen81 is offline   Reply With Quote
Old May 13th, 2010, 18:48   #2
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Requires 1997+ wiring harness using remote "180" glow plug relay.
Not appropriate for 1996 Passat with "103" glow plug relay in position #12.
Svante Arrhenius 1896
Old May 14th, 2010, 06:13   #3
jimbote
jimbote's Avatar
Interesting!!...do you have a how to thread link?
Old May 14th, 2010, 10:48   #4
paramedick
paramedick's Avatar
.....but Jeff has the ability to reflash the firmware on the JB so it functions perfectly as a GQ ECU for the 96 Passat. BTDT.
Old May 14th, 2010, 15:45   #5
Lug_Nut
Lug_Nut's Avatar
The ECU box and boards listed for sale will work with the '96 Passat wiring harness provided the presently installed chips are removed and a set of GQ chips are installed, but it's not compatible with the '96 wiring harness with any other chips such as the present JBs.
I just swap the chips: FA, GQ, ED, JB, all use the same hardware.
My former 1997 GLX Passat with 1996 TDI has an "FA" ECU with a "GQ" chipset brain transplant.
My Present 1996 Passat has a Jetta "ED" ECU with "GQ" brain transplant in it.
My Cabrio with the Jetta TDI engine has the '96 Passat "GQ" ECU with "ED" brains in it.
Old May 14th, 2010, 19:24   #6
Wildwr
TDI(s): 1997
Default ECU 1998 Jetta TDI
$210 shipped in the US.
Do you still have this ECU?
Wildwr is offline   Reply With Quote
Old May 15th, 2010, 07:32   #7
Spulen81
I just PM'd you back. It is still available.
Old May 22nd, 2010, 20:35   #8
ranman321
Have you sold the ecu yet?
ranman321 is offline   Reply With Quote
Old May 25th, 2010, 14:48   #9
Spulen81
Nope, lots of interest but no money yet.
Old May 28th, 2010, 17:07   #10
Spulen81
Just in case anyone else wants to ask if its available and disappear. Its still available.
Old June 24th, 2010, 06:38   #11
Spulen81
Still got it.
Old July 12th, 2010, 08:18   #12
Spulen81
SOLTed
Page generated in 0.14474 seconds with 10 queries
[Output: 100.90 Kb. compressed to 83.38 Kb. by saving 17.51 Kb. (17.36%)]
