Old January 15th, 2006, 18:06   #1
rsd
rsd's Avatar
Fuel Economy: 55 mpg
Default 97 Passat B4 - Seat heater burnt a hole through the seat . Recall?
Hello,
I turned my car on to let it warm up tonight and when I returned the passenger side seat heater (set to 3) had burnt a hole through the front of the seat. I'm lucky nothing caught fire and the damage wasn't worse but I'm sure this isn't normal and a definite safety hazard.
Is there a recall for this problem? I probably need a new seat on the passenger side now. Who should I report it to?
Andre
Montreal, Quebec
97 B4V TDI 270k (km)
rsd is offline   Reply With Quote
Old January 16th, 2006, 09:11   #2
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Report it to your insurance company. Prepare for a premium increase.
Don't say to them that the vehicle was unoccupied. Say that the passenger got out and the right seat was then unoccupied. Say that you didn't notice that the passenger's heater was turned on. Say the heater malfunctioned while you were driving. Say that you didn't see the seat discoloring from the heat because of the darkness in the car that night. Say that at first you presumed the slight odor you barely detected (you had a cold) was from the vehicle ahead of you.
Does the owner's manual not have warnings about leaving the vehicle or seat heater running while unattended?
Likewise, I should turn off the water to the clothes washer when it is not in use.
Svante Arrhenius 1896
Old January 16th, 2006, 09:57   #3
rsd
rsd's Avatar
Originally Posted by Lug_Nut
..Does the owner's manual not have warnings about leaving the vehicle or seat heater running while unattended?
Thanks Lug Nut,
I bought the car second hand and it didn't come with an owner's manual, so I'm not sure what it says about seat heaters un-attended. I'm assuming that the thermostat was faulty and let the heating element heat to a temp that cook foam and fabric. I'm going to check the fuse to see if it burnt out.
Old January 16th, 2006, 11:19   #4
RIP TDI
Saab (and presumably some other manufacturers) seat heaters have weight-activated shutoff switches in the seats. I'm suprised Passats apparently don't.
- Chris
'15 GSW SE 6MT, '01 Golf 5MT
'97 Passat sedan, '96 Passat variant
'99 BMW M3 Cabrio
RIP TDI is offline   Reply With Quote
Old January 16th, 2006, 21:42   #5
wastegate
Default same problem here
My driver side seat did the same thing ; burnt a hole in the seat. b4 1995 passat wagon.
wastegate is offline   Reply With Quote
Old January 21st, 2006, 15:56   #6
dld
dld's Avatar
Lightbulb Passat heated seats
The heated seat on our 97 Passat (cloth) was replaced under a recall, no charge to me, in the fall of 2003. Your dealer should know about the recall, or call VW Canada. I don't think there was a time or mileage limit.
Doug
97 Passat TDI 329,328km (sold!) - 99 New Beetle TDI 130,000km and now a 2005 B5.5 TDI wagon
dld is offline   Reply With Quote
Page generated in 0.13427 seconds with 10 queries
[Output: 71.51 Kb. compressed to 61.93 Kb. by saving 9.58 Kb. (13.39%)]
