turbo technical database
Turboworks
Eastbourne, UK
BMW X5 3.0 D
Definitely NOT for a Giulia 2.2 210ps.
It is KKK, so I expect weak shaft (slimmed down), nothingfor serious tuning. You shoul go GTD1752VRK way. How I already wrote: I don´t know about better turbocharger for 1,4-2,3l.
Yes, you are right I did some research and turbo 53039700457 it definitely is not for Gulia 2.2. Most likely would be turbo OE number: 55279544 or as you wrote GTD1752VRK. Garrett turbocharger 845210-0006, 845210-0010, 856473-0001. We made corrections on the website, sorry for inconvenience.
lewo
Turkey
AR Giu 1.6 jtdm2
Hi guys
Do anyone knows the specs / diameter of this turbo; 860517-5003s - GTE1449KVZ
Turbo Z
Sweden
Audi A2 mercedes c270
I have one of those gtc4088bknv and will update here with measurements when I take it apart.
The GTC4088BKNV 789500-5020S is a 11 blade compressor indusor 58,9mm, exdusor 88,36mm, superback, ported shroud A/R 0,60, rpm sensor, turbin 68,4mm exdusor 10 blade, it is a really heavy baster, somebody know the wiring diagram for the Rea autonator?
exhaust turbine in T5 två with holes and two with threads, out is 105mm v band, compressor house v band out 75mm, in 100mm with expanded front for house fitting with house clamp
normally find on cursor 9 engine, 8,7L, 2200rpm, 24 valves, 250/380/420/390/435kw
OilBomb
South Africa
1.9TDI Polo 9n3 - PD100
My experience. Sharan AUY. Photo of gauge to let you look at pedal response and boost rise. IMHO best possible turbocharger for 1,6-2,3 diesel used as daily. Capable for 235 hp on 8V PD.
The youtube video states VK but the question was around the VRK, so which turbo do you have bud, VRK or VK?
síťan
Valtice
1.9tdi 118kw ibiza
Zdravím vás. Montovat si někdo do auta turbo bmw bi turbo to větší gte30vzk jak to tady už bylo zmíněno? Zajímá mě náběh a zda je turbo na kuličkových ložiskách. Přemýšlím že bych si ho dal do své ibizi cupra 1.9tdi. Předem děkuji.
J_dude
SK Canada
2003 1.9l “Jedi”
I'll save everyone else the legwork and post the google translate results here:
"Greetings. Has anyone installed a bigger gte30vzk turbo in a BMW bi turbo car as it was already mentioned here? I'm interested in starting up and whether the turbo is on ball bearings. I'm thinking of putting it in my Ibiza Cupra 1.9 TDI.
Thank you in advance."
