Keyless entry wont work
06tdiesel
Seattle
2006 VW Jetta TDI
Hey guys so I've tried everything I could, bought a new transmitter changed batteries, tried programming with one key in ignition and turning the key in the door lock and nothing. I'm trying to located where is the keyless entry module located at? Can anyone help out, this car has been driving me nuts with all these little issues.
narongc73
VA/OH
2006 Jetta TDI
Did you check the door wiring harness? Jettas are not for everyone. If you like to tinker, it's perfect.
sptsailing
Safety Harbor, FL
2006 Jetta Manual, stock with Panzer Plate & Franko6 modified EGR cooler & CAM
The problems you describe will show up as errors when you use your VCDS Vag-Com to read the codes. You do have one of these, right? It is probably a bad motor in the door latch assembly.
06tdiesel
Seattle
2006 VW Jetta TDI
I just ordered new door latch for the drivers side. Could that be the reason the remote is not responding? Because the car doesn't even make a sound as if it doesn't read it. And I also just ordered vagcom cable.
06tdiesel
Seattle
2006 VW Jetta TDI
I dont mind working on it. I recently replaced the camshaft myself. But these electrical problems are never ending seems like.
oilhammer
outside St Louis, MO
Never ending if you have no way of actually diagnosing, for sure.
VCDS will let you "see" into what is going on. OBD works. I am betting you have at least one, possibly several, bad door latches, maybe a door harness too.
