06Jetta-Lane
I've had an issue with adjusting the a/c temperature for quite some time. As you turn the dial from full cold to full hot slowly, it should go from ice cold- cold- room temp- warm- hot. Mine stays ice cold all the way until you get to just before full hot. Luckily, here in Memphis, it's been hotter than Satan's sack outside until after dark so full cold is fine. But I'd like to get this fixed before fall comes around. Any suggestions on where to start or has anyone else had this issue?
