(insert funeral dirge)
I'm think I'm at the end of my road with this car. After my last post I drove the car for two weeks and put on 200 miles with out any problems. Then the next time I hopped in to take off...the accelerator pedal stopped working again and the check engine code came up. Below is a copy of my autoscan. While I had vagcom hooked up to it, the car suddenly stumbled or shuddered (kind of like it misfired) and the vagcom disconnected from the ECU as if I had unplugged the cable or turned the car off. I thought this might be a clue that something was wrong with the ECU. I had a spare, so I swapped the different ECU in, but nothing changed. My final conclusion (with VERY LITTLE confidence) is that there is a wiring problem somewhere and I have no idea where or how to track it down. Unless I'm suddenly struck with a bolt of inspiration or somebody has a new idea, then I think I'm going to part the car out this fall and start looking for a new car. I was only 4,000 miles away from crossing the 400,000 mile marker...so sad. If anybody has any ideas, let me know.
-Crdouger
Thursday,20,June,2019,16:36:51:17727
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64)
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: 3VWDT71K66M631789 License Plate:
Mileage: 636910km-395757mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 56 62 72 7D
VIN: 3VWDT71K66M631789 Mileage: 636910km-395757miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E2458333
Coding: 0050071
Shop #: WSC 00066 000 00000
VCID: 63EB673BA2108752A0-8036
2 Faults Found:
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 636917 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:24
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Mass Air / Rev.: 215.0 mg/str
Duty Cycle: 95.1 %
Bin. Bits: 00000000
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 70
Reset counter: 255
Mileage: 636917 km
Time Indication: 0
Date: 2000.00.00
Time: 19:44:59
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00101100
Idle Stabilization: 0.0°KW
(no units): 48.0
Readiness: 1 1 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 40A188B713C6FC4A9D-8014
2 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BA
Component: ClimatronicPQ35 066 0606
Shop #: WSC 00000 000 00000
VCID: 67F3732B5628EB727C-8032
2 Faults Found:
00402 - Auxiliary Air Heater Element (Z35)
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000106715
Coding: A4019E234104180000140000001400000008770B5C
Shop #: WSC 03087 444 54618
VCID: 2B7BCF1B8A400F1258-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 03087
3 Faults Found:
00483 - Control Module for Auxiliary Air Heater
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 194
Mileage: 632670 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
01207 - Control Module for Auxiliary Heater (J364)
Freeze Frame:
Fault Priority: 2
Reset counter: 194
Mileage: 549387 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 194
Mileage: 551507 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.50 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E3026588
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 232
Mileage: 536587 km
Time Indication: 0
Date: 2000.00.00
Time: 16:34:39
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD02NA80
Coding: 0012627
VCID: 2E7DC60FB9527A3A7F-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME0A1B43459
Subsystem 3 - Serial number: 6342MSME0A025A1EE
Subsystem 4 - Serial number: 6351HSME07012243T
Subsystem 5 - Serial number: 6361HSME072F206BB
Subsystem 6 - Serial number: 63727SME070F4B669
Subsystem 7 - Serial number: 638 SME
1 Fault Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
010 - Open or Short to Plus - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002021
VCID: 7AD53A5F359A669A93-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 972 D
Component: KOMBIINSTRUMENT 3HL 1112
Coding: 0023203
VCID: 2D7FC103B454012246-8078
1 Fault Found:
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105423825C
Coding: 3D7F0B600F1002
VCID: 2A75CA1F85BA161AA3-807E
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 194
Mileage: 632670 km
Time Indication: 0
Date: 2000.00.00
Time: 06:44:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 144
Reset counter: 194
Mileage: 636713 km
Time Indication: 0
Date: 2000.00.00
Time: 05:45:22
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T00YK01
Coding: 0000003
VCID: 3957E553701CAD82DA-806C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1112
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 A HW: 3C0 959 760 A
Component: Sitzverstellung 0601
Revision: 00002000 Serial number: 00000000000000
3 Faults Found:
02327 - Position Sensor for Front Seat Height Adjustment (G438)
006 - Short to Plus - Intermittent
02332 - Position Sensor for Backrest Adjustment (G440)
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001269
VCID: 364DEE6F410242FA37-8062
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106083F6D060F8FB008CF0480A540
Shop #: WSC 03083 444 179286
VCID: 022542BF5D4A2E5ACB-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01110011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Time Indication: 0
00849 - S-contact at Ignition/Starter Switch (D)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 636670 km
Time Indication: 0
Date: 2000.00.00
Time: 21:04:55
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 3753E36B4608BBF22C-8062
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E2029530
Coding: 0040400
VCID: 20612837F386DC4AFD-8074
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3147DD73A86C65C262-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245D27FAD6A5EDA1B-8066
Address 7D: Aux. Heat
Cannot be reached
End-------------------------(Elapsed Time: 01:21)--------------------------
