I have a 2005.5 Jetta with the premium system radio (satellite, etc.). The issue is the reception is horrible (if at all). Does not receive local FM stations (can barley hear) and there is a "clicking" in the drivers side front speaker in the door when you turn the radio on. Clicking goes away (slowly) when the radio is powered off. I know this is a working radio so it has to be in the wiring etc.
When I use my VagCom to run diagnostics on the radio I get the following codes:
00668 - supply voltage terminal 30
002-lower limit exceeded- intermittent
00856 - radio antenna
011-open circuit - intermittent
00821 - Antenna 2 for radio (R93)
011- open circuit - intermittent
Has anybody ever run into an issue like this?
