tikal
I have a coolant leak that shows up in my garage floor from time to time. It is approximately in the middle towards the passenger side. Previously my Passat had the tandem pump coolant leak fixed ($$) about three and half years ago (fuel pump gasket, cooling hose flange & water temperature sensor R&R. Cooling system flush and bleed).
I also hear quite often the sound of the coolant gurgling when I start driving.
Thoughts?
Thoughts?
