wingrider02
Hey All,
It seems that I have a bit of a leak on the rear drivers door of my Golf. Has been good as long as I have had it, but a couple weeks ago the floor board had a good couple of inches in it after a good rain.
I thought that maybe the door was left open, and didn't think much of it. Well, it rained most of last night, and when I hopped in to go to work, figured I better check...sure enough, there is a good inch of water in the floor board. The seat is also wet, so I figure it is coming from the top, and not from the bottom up.
I shot a picture of the headliner, and of the one seal that looks bad...all the other seals appear to look good, but I must confess that I haven't done a lot of work with door seals. The one with the spot out of it has been that way for over a year, and hadn't leaked, but I figure that can't be good.
Would anyone care to take a guess if this damaged seal is the one doing the leaking, or do I need to look further?
Thanks for any help!
Here are the pictures I took....This first one is of the headliner, and the second is of the seal with the fiber on it.
