Stevestyle67
2003 Jetta TDI 69,000mi
Here is the problem...
The car runs just fine, but has a lot of bubbles in the fuel line and the IP is losing its prime, making the car very difficult to start. Its obvious that there is air in the fuel line b/w the filter and IP. When you shut the engine off the fuel from the IP rushes back through the fuel supply line/filter and back towards the tank. Checked the fuel tank in case there was some sort of blockage and it was clean as a whistle. The IP is not leaking and there are no fuel leaks anywhere. Seems like the only thing left would be an air leak in a fuel supply or return line, but wouldnt there be a fuel leak somewhere if this were true? This same problem has occured with 2 different fuel filters. Occured while a aftermarket fuel filter was in the car and while a VW filter was in the car. The kicker is that this problem only occurs when i put regular diesel fuel in the car. I have never had the problem when the car was running on biodiesel. Anyone have any ideas what is going on here? This work has been done by Import Autowerks in Raleigh, NC....I took it to them b/c they were on the forums mechanics list, but they seemed a little stumped by this.
