Pillote
My IP started leaking about a week ago. I read the links on replacing the top seals and heeded every warning out there. Unfortunately, the new top seals did not stop all the leaking, but it did stop most of it. There was still a good drip every couple seconds from the bottom of the pump, so I pulled the pump out.
From what I could tell, the leak was either coming from the head of the pump or from the cold start solenoid.
I have the entire seal kit for this pump and started replacing the seals one by one. I did all but the pulley seal and they seem to have gone together well. I made sure the pin was in the bleed off collar (as best I could).
I re-installed the pump and adjusted the timing with the lock/TDC method. I then used a vacuum to pull fuel up to the #1 cylinder return line. Finally, I started cranking and cranked until the battery died. I pulled the fuel line at the number 1 injector and it's dry. Should I have fuel by now? I'm concerned that I botched my pump while installing the seals, but it was a last ditch effort. It was functioning prior to the seal replacement.
I've never used biodiesel.
