UhOh
That's confusing
Lemforder doesn't make Cupra R axle bushings that I'm aware of. And everything that I've ever read says that the Cupras are solid (it's the orientation of voids in the others that requires special alignment). I've installed two sets of the Cupras and neither set came with any information, no orientation noted. I did, however, line up the aluminum ears on the bolt sleeve such that they pointed at the magic points on the axle beam.
