Old May 31st, 2020, 06:00   #1
JohnPaulJones
TDI(s): Golf MK4 TDI
Default New Brake rotors and pads, 50% active???
Hi TDI Club.
So i put new rotors and pads on the rear of my MK4. I went driving in it for a while and regularly stop to check the wear pattern on the new rotors. So on the visible side of the right rotor it is clear that only half of the pad rubs against the rotor. That would be the half part closest to the caliber. (I hope that is explained well...)
I jacked up the car again and made sure nothing was wrong. I cleaned the slidepins and lubed them. I lubed all contact faces again.
So the manuel for the pads says to bed the pads for the first 200-300 km / 120-190 miles. Break softly etc.
I have only driven for like 100km / 60 miles at this point.
So do you guys think that the pad will eventually get contact with the whole rotor face or is something very wrong?
I only have this problem on this one pad.
Also another question: Is it normal for the rubber boot on the slidepin to create a vacuum, so that when you push it in it wont slide out again by itself? Thanks in advance guys!
JohnPaulJones is offline   Reply With Quote
Old May 31st, 2020, 06:56   #2
Mongler98
sounds like a defective pad it happens.
and yes they will act like a vacuum if pulled and pushed like that. they never move that much, ever, in application so its not an issue. you don't want water getting in there do you?
also bedding in pads are 1 of 2 schools
1: bindex uses a blue compound on the pad to make it bed in under normal driving. AWESOME. others do this as well .
2: go drive it and do a 90% stop from 40 mph to about 10 with as much braking force as you can with out locking the tires, do this about 5 to 6 times and the brakes will feel like mush, go drive for 10 minutes with no braking action like on a highway at night to let them cool, no full stop allowed.
i would check the face of the pad to the backing plate to see if its parallel. i bet you its not!. I had 2 similar issues with Hawks pads a while ago.
Old May 31st, 2020, 07:03   #3
Dh4276
As for the wear pattern, that does not sound normal, you should have even wear across the whole pad, especially with new pads and rotors!
Did the piston slide in easily when you pushed it in? I have seen on some cars (not on VW) where the is a lip that can get caught on the piston when pressed on the way is causing it to hang. If the bottom is sticking it could be causing the piston to not come out in an even flat position thus causing this odd wear pattern. Can you tell if the wear is gradually less as it moves towards the hub?
As for the slide boots, I have seen this many times caused by the grease in the boots! Seen it on many different vehicles including VW.
Dh4276 is offline   Reply With Quote
Old May 31st, 2020, 07:06   #4
Dh4276
I have always used the second break-in option, has always worked great for me!
On the pad issue, that is also another possibility, Iíve never had it but I donít think it is out of the question, just didnít think about it!
Old May 31st, 2020, 09:47   #5
JohnPaulJones
Thank you guys. So you confirmed for me that this could not be normal behavior.
I took a nap and thought about it.
If there would be grime and dirt in the caliber where the pad is sitting, that would account for the wear pattern because the back part of the pad would be slightly farther out because of said grime and dirt.
And sure enough, i had not given the the old metal wire brush to the caliber. I took apart both brakes and cleaned them.
I now seems to have a much more normal wear across the whole rotor.
You can write this off as another weekend mechanic, not doing the job right the first time
Thanks again. Cheers from Denmark
Old May 31st, 2020, 16:48   #6
Mongler98
That's got to be a lot of crap behind the pad!
Makes sense though. Big step is to clean all the mating surfaces and grease them.
Glad its sorted
Old June 5th, 2020, 07:35   #7
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
It depend of Brand. Some brands takes a while to brake in and never do brake job as quality brand does.
What brand of pads and rotors you got?
USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic,
I do any repair on all models,
ECU TUNING/PROGRAMING-MK6 Needle Sweep,MK5 with MK6 Cluster
https://www.advancedcarelectronics.com/
jetta ,97 is offline   Reply With Quote
Old June 5th, 2020, 09:03   #8
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
If you've been very gentle with the brakes, I would take it out and do some hard braking.
But yea, excess rust and crap on the mating surface will do that.
Brake pads and rotors crustodd VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 8 May 18th, 2020 17:47
FS: JSW Mk6 Rear Brake Rotors/pads NIB $50 - Houston, TX sulrich Private TDI Items for Sale/Wanted 0 May 25th, 2017 08:47
New brake rotors/pads and new brake fluid on TDI MK4, some questions! matgat TDI 101 2 November 14th, 2011 15:07
01 NB brake job-new pads? or pads & rotors? treetopflyer VW MKIV-A4 TDIs (VE and PD) 14 December 5th, 2006 01:26
Brake pads / rotors -- which ones? tjl VW MKIV-A4 TDIs (VE and PD) 16 January 16th, 2006 13:26
© 1996 - 2020, All Rights Reserved
Page generated in 0.17580 seconds with 11 queries
[Output: 87.44 Kb. compressed to 75.78 Kb. by saving 11.66 Kb. (13.33%)]
