Old May 28th, 2020, 02:04   #1
taztaz
TDI(s): vw bora
Default fuse box ahu help
hi, all I'm in the middle of a ahu conversion on my mk1 caddy I have a ahu with a wiring loom I brought it already taken out of the donor car ... I'm just having trouble with the H1 plug in the ahu fuse box I have read the forums but just need it simple terms? I'm looking to do a bench test so I can see if there's anything wrong with it as I've not heard it running
this is what I've found ...
H1/01 Ignition Switch Starter Run, or from Starter Interlock Relay Main Fusebox Starter Power Red/Black
H1/02 Ignition Switch Battery Power Battery Power Red
H1/03 Ignition Switch Run Power Load Reduction Relay Power Black/Yellow
H1/04 Ignition Switch Start/Run Power Main Fusebox Start/Run Power Black
taztaz is offline   Reply With Quote
Fuse Box pmoulton5018 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 19 December 17th, 2019 11:41
AHU Harness and fuse box and other mk3 parts vtpsd Private TDI Items for Sale/Wanted 4 September 18th, 2018 10:48
Pictures of a 1998 AHU Jetta TDI Fuse Box G60ING TDI Conversions 0 March 26th, 2013 10:10
Fuse Blown in enngine compartment - not in fuse box w/ rest of fuses. 97 Passat Thilicynweb TDI 101 7 August 25th, 2008 16:28
where is the fuse box? CC13 TDI 101 5 September 12th, 2006 05:01
Page generated in 0.12706 seconds with 11 queries
[Output: 47.12 Kb. compressed to 44.44 Kb. by saving 2.68 Kb. (5.69%)]
