Old May 20th, 2020, 15:33   #1
jimbote
jimbote's Avatar
Default ALH @ 50 Degrees with stock pan.
Has anyone done this? i know the pickup would need to be modified to compensate. Would this put the crank in the splash zone?
jimbote is online now   Reply With Quote
Old May 20th, 2020, 18:56   #2
[486]
TDI(s): 02 golf ALH
my insight is at 60 deg, even with the pan kicked out way far like the vanagon's one it still only barely holds 4qt from a dry engine before it starts getting too close to the crank for comfort
I do have yet to drive it enough to get a feel for oil consumption yet though, so I may well be able to get away with increasing the fill level further.
The biggest thing I noticed that just made me feel real dumb is that it looks like the injection pump sticks up just as high as the cam pulley would have at the stock 15 degree angle, also the oil filter housing ends up poking up very high as well.
[486] is offline   Reply With Quote
Old May 21st, 2020, 03:30   #3
jimbote
jimbote's Avatar
so you have this setup with stock pan in your 2wd van? I'm assumed there might be clearance issues between the filter housing and the deck lid.
Old May 21st, 2020, 05:22   #4
[486]
TDI(s): 02 golf ALH
nonono, honda insight and modified pan, just that if I thought I could get away with not welding aluminum I would have. Every time I get the TIG torch out I end up shouting incomprehensible things.
the filter housing is relatively easy to chop the cartridge filter housing off, block off, then use parts from a 2.0 gas in order to utilize a cannister filter beneath the oil cooler. My golf is set up that way, only issue is needing to bend the AC suction line
Old May 21st, 2020, 07:08   #5
jimbote
jimbote's Avatar
ok, are you running the alh at an extreme angle in the insight?
Old May 21st, 2020, 15:03   #6
[486]
TDI(s): 02 golf ALH
see
I'll just stop trying to be helpful now. Sorry.
Old May 21st, 2020, 16:42   #7
jimbote
jimbote's Avatar
see
sorry man, post a bit confusing...just trying to understand your setup... you are running an alh @60 degrees in a honda insight?
Old May 21st, 2020, 16:45   #8
[486]
TDI(s): 02 golf ALH
indeed, used to have a build thread but all the pictures died along with tinypic
I'll try and fix it up somewhat, gimmie a few hours to figure it out
ETA: there we go, insight swap link in my sig, skip right to the bottom for the relevant pics of mounting angle and pan
Old May 24th, 2020, 21:04   #9
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
It's been done yes. I even found a company that offered an oil pan for about $800 at one point! I've been planning a 2.0BHW at 50 degrees, have most of the parts but haven't had a chance to start the project.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old May 25th, 2020, 02:21   #10
jimbote
jimbote's Avatar
is that the FAS pan? BHW would be sweet in a vanagon...is this 2wd?
Old May 25th, 2020, 20:24   #11
Uberhare
Uberhare's Avatar
TDI(s): Too many.
2WD Whitestar. I've got a euro 5 speed transmission for it.
Old June 1st, 2020, 09:04   #12
Zeitgeist
Zeitgeist's Avatar
Have you considered just installing at the stock 15 degree angle? My ALH install is configured that way, and it fits under the lid.
'90 300D OM606t
'89 Vanagon Bluestar ALH mTDI
'01 Eurovan Weekender AXK
Past: '96 Passat 1Z
Zeitgeist is offline   Reply With Quote
Old June 1st, 2020, 15:58   #13
jimbote
jimbote's Avatar
details? is this a 2wd? if so, is the engine lowered to syncro height? what mounts are you using? what adapter plate? thanks.
Old June 1st, 2020, 17:00   #14
Zeitgeist
Zeitgeist's Avatar
Hi, this a 2WD with the entire drivetrain lowered to Syncro height. I raised the suspension so that the ground clearance is just a tad below 10". I used a lot of Passat 1.8t parts, like oilpan, driver side engine mount arm and engine mounts. This swap was done on the cheap, so I work traded for the Kennedy adapter kit and the DK (aircooled) 4.57 R&P trans. It's a weird install, since most of the bits n' pieces are custom made, but it's kinda cool.
Here's a shot of the rear showing the ground clearance.
'90 300D OM606t
Past: '96 Passat 1Z
Old June 1st, 2020, 18:33   #15
jimbote
jimbote's Avatar
i dig it...looks like you used the stock wbx crossbar but lowered using brackets. And custom fabbed brackets to house the bhw mounts? I'm assuming the stock intake interfered with the lid? how much did it protrude above plane? ...i'm probably going to k.i.s.s. with this 82' 2wd diesel and do a 50* AHU with all the stock bits. I do like your approach, and may follow suit with my 87 syncro.
Are glowplugs necessary above 50 degrees? sohccammer427 TDI 101 12 June 22nd, 2013 04:42
Stock ALH/BEW oil pan for sale. turbocharged798 Private TDI Items for Sale/Wanted 4 May 5th, 2012 11:06
Stock ALH starter. $50. CT sardo_67 Private TDI Items for Sale/Wanted 0 November 17th, 2010 12:11
02 Jetta wont start under 50 Degrees. Got55mpg VW MKIV-A4 TDIs (VE and PD) 38 November 11th, 2010 11:38
Stock 5-speed nozzles for ALH - $50 majesticj Private TDI Items for Sale/Wanted 1 April 29th, 2007 13:49
Page generated in 0.17889 seconds with 11 queries
[Output: 136.27 Kb. compressed to 114.09 Kb. by saving 22.19 Kb. (16.28%)]
