Old November 23rd, 2018, 16:09   #91
superhl
When I purchased the S10 NV3500 tranny, it came with drive shaft and I did not have to make any modifications to fit the Isuzu. From what I researched, the S10/S15/Sonoma 92 through 97 3.73 differential should fit the NV3500 tranny. However, I will probably need to make modifications to fit the Isuzu. Spent most of the day stripping the paint preparing for a new paint job. Hopefully tomorrow I can find the time to go look. Just hope they have a tag so I can verify that I getting a 3.73. As far as crimping tools, I have all that and what I don't have my cousin who owns a trucking business has. Again, thanks for all the info!!!
superhl is offline   Reply With Quote
Old November 23rd, 2018, 17:24   #92
PickleRick
PickleRick's Avatar
Isuzu is an odd gm venture where i can't keep track of what's shared with the s10/blazer lines and what's Japanese.
You may get lucky and it's bolt in.
I love the old square body late 80 to early 90s troopers. Once I'm done restoring my cabin boat i plan on doing a bhw swap with an nv3500, dana 300 and a dana 44 sas.
I plan on keeping the 4:11 to 4:56 ish gear ratios and doing a large enough body/suspension lift to run 33 to 35 inch tires.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is online now   Reply With Quote
Old November 23rd, 2018, 19:44   #93
superhl
Troopers were well made vehicles. Don't understand why they quite making them. I guess not fancy enough for most people.That will be an awesome build. The Isuzu pickup I have is a solid truck. No rust. Everything manual. Very little to break...I loving this 1.9 ALH swap. Fuel mileage is awesome and plenty of power! I have to confess, it was not easy!
Old November 24th, 2018, 04:28   #94
PickleRick
PickleRick's Avatar
I'm sure the lack of mpgs plus the competition of the sua when they were introduced had a lot to do with it.
Many times vehicles like the trooper are sold for years elsewhere after being discontinued in the US market.
They are also usually sold with diesel engines elsewhere. Ford 1/4 and 1/2 ton turcks, land cruisers, monteros and land rovers all like oil burners else where. The rovers in the UK military got a 200 or 300 tdi. In Australia the rovers got the 4bd1 or 4bd1t. Im sure there are more that I'm not aware of.
Old December 9th, 2018, 15:52   #95
superhl
Not had time to get the 30 inch tires yet... I have another issue. Trying to get my heater fan to work. If I remove charge relay it works. Looking at the diagram below, where would I connect the white/blue wire from the charge relay on the generator. It appears this wire powers the heater relay allowing the fan to run??? I am using the VW alternator. Or am I wrong.
http://repairguide.autozone.com/znet...52800627d9.gif
Old November 29th, 2019, 11:57   #96
superhl
I replaced my quantity adjuster upper and lower seals on my injection pump last week. It ran fine except takes several rotations (4-5)to start- it has been taking 4-5 rotations in the morning for a while. Once started, it starts on first rotation. Wednesday I replaced IP head seal from Diesel geek. Was very careful although I did drop shutoff solenoid and spring fell out. It took me an hour to find it. Only found a spring and black plunger was still in the housing? Is there more parts? After installing the solenoid it was easy to prime and start. After driving down the road I noticed weak deceleration- turbo lag. Today, ensured all the pipes were tight, drove and black smoke poured out. I checked the timing and appears to be off the charts- advanced. How does changing the IP head seal affect the timing? If a part is missing from the Solenoid, would it cause the black smoke? If I damaged the seal, it should be very hard to prime and if started should see white smoke. Thanks
Old November 29th, 2019, 15:29   #97
jmodge
Cold start injector could be stuck open
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old November 29th, 2019, 15:31   #98
jmodge
http://forums.tdiclub.com/showthread.php?t=502801
I would think you would get a code though
Old November 29th, 2019, 19:04   #99
superhl
Here are the codes
Friday,29,November,2019,21:48:17:09494
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
Address 01: Engine Labels: 038-906-012-AGR.CLB
Control Module Part Number: 038 906 012 FF
Component and/or Version: 1,9l R4 EDC G000SG 4104
Software Coding: 00002
Work Shop Code: WSC 00066
VCID: 59EF8EE2000B23AFEE9-4B5C
5 Faults Found:
17068 - Glow Plug Control Module (J179)
P0684 - 35-10 - Implausible Signal - Intermittent
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 35-00 - Signal too High
16491 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0107 - 35-10 - Signal too Low - Intermittent
17569 - Manifold Temp Sensor (G72)
P1161 - 35-10 - Open or Short to Plus - Intermittent
17656 - Start of Injection Timing Regulation
P1248 - 35-10 - Control Deviation - Intermittent
Readiness: 1 5 0 0 1
Address 01: DTCs cleared
Fault Codes have been Erased
8 Faults Found:
Readiness: 1 4 1 1 1
Old November 30th, 2019, 08:18   #100
jmodge
Check or unplug your maf
Old November 30th, 2019, 08:44   #101
superhl
MAF is is unplugged. Here after re-seating the CTS and MAP.
2 Faults Found:
Old November 30th, 2019, 10:00   #102
superhl
Output test cycle the N108. Doesn't appear to be stuck.
Old November 30th, 2019, 11:34   #103
Motohead1
You said the pump is very loud? Are there any air bubbles in the return?
Dodge Dakota QC Tdi
Motohead1 is offline   Reply With Quote
Old November 30th, 2019, 11:57   #104
jmodge
They don't necessarily stick stationary, and since I can't see or hear what you do, I have to ask why do you think it doesn't appear stuck?
Have you compared specified and actual timing? Also have you watched the timing while the valve is being cycled to see if the timing comes down to the high 50's low 60's?
Old November 30th, 2019, 12:27   #105
superhl
The mechanical timing was way advanced. Readjusted and now back to slightly advanced. Runs good but not quite the power as before. No smoke! I will compare late this evening and post....Only codes is
Thanks!
Hoping tomorrow morning is will start without 5-6 engine rotations.
1992 Jetta TDI swap malone tune Thaines28 TDI Cars for Sale/Wanted 0 December 30th, 2015 09:51
swap TDI 1992 a 900$ Smog Quebec 0 July 6th, 2005 04:05
** FS : Jetta 1992 with 1998 TDI SWAP with mods ** GiGGer TDI Cars for Sale/Wanted 1 March 9th, 2005 21:45
Jetta 1992 avec Swap TDI 1998 a vendre GiGGer Quebec 1 March 1st, 2005 11:48
Jetta 1992 with TDI 98 complete Swap in Canada, QC GiGGer TDI Cars for Sale/Wanted 2 January 3rd, 2004 12:43
© 1996 - 2020, All Rights Reserved
Page generated in 0.19714 seconds with 11 queries
[Output: 128.98 Kb. compressed to 107.64 Kb. by saving 21.34 Kb. (16.55%)]
